Derive fixture
Derive fixture
nubrandao
Message 1 of 25
Derive fixture
nubrandao
Hi, maybe I'm doing something wrong
I usually start open a step file, component, sketch, some modify in the model and save.
Now, I derive a fixture like a vise.
I choose a vise and ok
Then start joint a my vise to my component, but starts asking to capture position, and the parts move, I can joint, but I usually don't get at firsts,
It's important that my component don't move, only the fixture,
Should I break link of my fixture?
The I need to flip my fixture vise,
Derive again a new one,
Most the time the component move, some time revert position,
But when I start machining, the stock from the first don't align with the second
My question here is:
In order to my part be always in the same position, what should I do?
Ground parent?
Break link fixture? Capture position?
Accepted solutions (4)
Replies (24)
Message 2 of 25
Drewpan
I would strongly recommend that you do the embedded tutorials in the Fusion Documentation and also some of the
Self-Paced Learning to help you to learn fusion faster and better. They can be found here:
It is also much easier for the forum to help you if you attach your file AND a screenshot of what you want to achieve
and what the problem is. You can create a file to export like this:
Ok, Lets try to solve your problem. It would really help if you attached your file here but from what you have described
you seem to have a problem with creating components and moving them around.
When you create a model, every separate part of the model should be a separate component. Your main component
should be grounded to stop it moving around. A recent update of fusion should do this by default but I have not
actually noticed this behaviour so at least check to see if it IS grounded.
You then have two different methods of designing new components and assembling your model. You can use the
method where you design every new component at the Origin and then use Joints to connect them to the model. Or
you can design the component in place where it is meant to be and then use an As Built joint. Either way you need to
actually use Joints to connect the components together. If you do not use joints then when you move something
then you will only move that something not everything joined to it.
I would strongly recommend doing the embedded tutorials in the documentation and the Self Paced Learning that
is provided by AutoDesk. It shows you how to create and use joints well.
Do NOT just simply use the Move command or Copy/Paste commands to move stuff around unless you REALLY need to.
While you will sometimes need to use these commands they are not there to move stuff because you cannot see what
you are doing. The Eye icon on the browser tree is to turn visibility on and off and should be used when you cannot see
stuff.
Using the Move command causes fusion to re-calculate the model every time it finds the Move icon in the time line.
This can seriously affect the performance of fusion. If you have multiple Moves then fusion re-calculates for EACH one
of them, even if the thing you did immediately before was move something else.
It is possible to avoid this by disabling the time line but again, there are times you should do this but it is often better
NOT to do it. If you don't know how the timeline works then do the tutorials and self paced learning. The timeline is
a very powerful modelling tool and makes fixing problems much easier.
Hopefully this has answered your question. Next time or if you have more questions then attach your model or at least
a screenshot of what the problem is. It makes it much easier to help people when they do.
Cheers
Andrew
Message 3 of 25
nubrandao
Thank you very much, I will try to attach some screenshots
I will try some tutorial
How can I Screencast?
Message 4 of 25
Drewpan
There is a series of RULES that are pinned to the top of the forum. These will help you to learn and use fusion. The
best way to go about it is pick something you like and model it. When you get into trouble post a question. Do this
often and you will learn fusion quickly and it is well worth it.
There was a plug in for fusion to screencast but it is no longer available. I use software called OBS but if you google
there may be better software out there. I don't use it very often myself.
Good luck with your modelling.
Cheers
Andrew
Message 5 of 25
nubrandao
I saw the rules, but I have to admit I dint saw for a long time, I have to
check it again.
I still use fusion has learning software because 90% of my work is still in
powershape and powermill
We still have a short dead line to deliver work so I avoid using a lot
fusion because of some issues I find .
Message 6 of 25
nubrandao
I made I video. I'm still very weak in cad department
What I can do better and how to solve the stock problem
Message 7 of 25
nubrandao
Video
Message 8 of 25
Drewpan
In all honesty you will get out more than you put in with fusion. Spend the weekend and a few hours to get your head
around it and fusion will become a powerful tool. It is well worth the effort.
Cheers
Andrew
Message 9 of 25
nubrandao
I really like fusion, more then powershape, but like you said, need more time practice fusion
Message 10 of 25
a.laasW8M6T
Hi
This is what I do for my workflow, Although I don't often bother with inserting the Kurt Vice for the final operation, but it is nice for visualization
My workholding templates are based on this Autodesk University presentation
is is from a few years ago but the fundamentals still apply.
https://www.autodesk.com/autodesk-university/class/Streamlining-CAM-Workflows-Templates-2019
Now with configurations(and other improvements to fusion like Sync View and visibility) its much easier.
I've attached my template if you would like to see how its setup, I don't think you use zero point/lang in your work but you may be able to adapt it to your workflow.
I also use this add-in  to quickly open a template, insert the active part file into it and save it, its a gamechanger for this type of workflow.
https://github.com/schneik80/IMA-PowerData
EDIT:
The part of the add-in that opens and inserts files into the template is Related Data, this is integrated with this add-in and improved from a standalone version but doesn't contain instructions on how to configure it.
Th instructions can be found here for the Standalone add-in:
https://github.com/schneik80/Fusion-Create-Discipline-Document
Andrew Laas
Senior Machinist, Scott Automation
Message 11 of 25
nubrandao
It sound easy in the video.
I have to create vise with vise parametric
Don't you recommend manufacturing mode? It's seems easier for me... but don't the consequences
Message 12 of 25
a.laasW8M6T
Hi
Its a bit of work to create a template but once you have it its is dramatically faster.
I wouldn't use Manufacturing Models AT ALL, they don't work properly as you have found with transferring stock from preceding setups, all your workholding models etc should be done in Design only.
Manufacturing models were really designed for nesting/ arrange workflows, they do not have the ability to use sync view and visibility.
Andrew Laas
Message 13 of 25
nubrandao
I already worked in 4 parts using manufacturing model, at the beginning, to get the stock right, I save stock has .STL, then import again, and make the model and stl rigid group.
What I didn't understand why the stock was in a different location every time I flipped the vise.
Later I saw that during joint, my part was moving, if a revert position, my model went back to his original position and then my stock became in the same position when changing setup.
I still have have sync view perfectly working with manufacturing model.
Can you try again and see if manufacturing model is now working properly?
 My question is because I'm teaching the first steps to my college at the company, I told them to use manufacturing model... I just want now to be certain if using vise is always better in design
Message 14 of 25
a.laasW8M6T
Again I wouldn't recommend using Manufacturing models, they may have made improvements to them since I last used them years ago but I find it to be an unnecessary extra amount of work, plus all the benefits of the parametric configurable vice/stock wont work in a manufacturing model.
If you have to use .stl for stock and have to use capture positions or revert positions then there is definitely a problem.
I'm not sure if others use this exact work flow but I believe this is the "Correct" way of doing things, its a bit hard to know without seeing exactly what you are trying to achieve.
Andrew Laas
Message 15 of 25
nubrandao
I just created a paramedic vise, very cool, I did like you said for the second vise, set the part width, etc. was cool
And you right
I can make all the assembling vise at work, then just go to manufacturing and set the setups
Message 16 of 25
nubrandao
how can i set properly in this vise?
the basic one is solved, but this one, dont know were the joint point is to be properly set my stock
Message 17 of 25
a.laasW8M6T
Hi
I have uploaded the configured version of my vices in a previous reply to the thread, it would be worth looking at that to see how its done there, the trick is that the stock isn't jointed to the vice at all, its jointed to the origin, the vice is also jointed to the Origin, that way they share a common reference
Here is a short video explanation:
Andrew Laas
Message 18 of 25
nubrandao
Very nice, being in the origin is better
How do you record your videos?
Another question I'm still confused
For example, I have 2 or 4 identical parts.
I want to machine once.
I know how to do setup and multiple offsets.
But in this situation, I want to see all my parts in the setup, I want to pattern.
When I start the setup, should I only choose one part, do all the toolpath, then pattern ?
Or in the setup I must put all the parts and program only one part?
The question is if I have multiple parts in the setup, everytime I calc a toolpath,it trys to machine the other parts unless I create a boundary.
What's the best way to do this?
Message 19 of 25
a.laasW8M6T
Hi
I use OBS as a screen recorder, its free:
https://obsproject.com/
as for the multiple parts, I'll have to have a think about that and get back to you, Its not something I do often as we really only make one offs most of the time
Andrew Laas
Message 20 of 25
a.laasW8M6T
Hi
See video on my thoughts on patterns in Fusion.
Andrew Laas
