Decal - transparent background
Hrvoje-
Hrvoje-
Hi!
I made the picture for the logo in Corel and marked the colour (white) of the transparent background. I tryed with "png" and "jpg" file but I can not obtain the log without the white area. I can not find what I am doing wrong.
Can I get help, please?
Kind regards,
Hrvoje 🙂
michallach81
First, it need to be .png, jpgs don't support transparency. In Corel export just those red and blue objects, without background. In export option check Transparency option... that should work.
Michał
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
HughesTooling
Does Corel have a way of setting transparency in the picture. I use InfanView to adjust images and at export you can pick a colour that will be transparent.
Mark
Mark Hughes
Owner, Hughes Tooling
michallach81
Corel is a vector graphic program so I've assumed that he is working on vector objects... if so theh he just need do select what he need witout any background.
Michał Lach
Designer
co-author
Hrvoje-
Thank you all for the help! I accepted as the solution use of Irfanview. The solid looks now like this:
Kind regards,
Hrvoje 🙂
