I'm going to be printing a part which will have text debossed on the top and bottom faces. Deboss defaults to a square cut "trench". Can I change this to round so it cuts a round trench? This could make supports unnecessary when 35 printing cause it won't have 90 degree overhangs.
Solved by jhackney1972. Go to Solution.
It is not an automatic feature and you will have to play with the radius but Rule Fillet can do it. Model is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Great thank you - I was thinking I would have to do some profile cut, following the letters as the path. Your solution makes it much simpler. Take Care.
