Dashboard viewer units problem.
HughesTooling
Consultant Consultant
HughesTooling
I just noticed the online 2d drawing viewer does not use the correct units when you use the measure tool.
Here it shows 1.969 inches not 50mm, I don't think there's any way to change the units in the viewer.
The 3d viewer seems to work OK, perhaps someone working in inches could try the same test.
Mark.
Mark Hughes
Owner, Hughes Tooling
Jon.Dean
Hi Mark,
I agree totally. I will investigate tomorrow.
Jon.
Jon Dean
Jon.Dean
Hi Mark,
It all depends on the Drawing sheet that you use.
If you select ASME then the measure command uses Imperial.
If you select ISO then the measure command will use millimeters.
You can change the units by selecting the Cog Wheel.
Jon.
Jon Dean
HughesTooling
Thanks Jon, that works.
Mark
Mark Hughes
