Hello, can someone please help me find the height of a cylinder? I tried Inspect-Measure, but it only shows Radius, Diameter, Area, and Loop Lenght. I also tried Sketch-Sketch Dimension but it is greyed out.
Solved by Oceanconcepts. Go to Solution.
Easiest would be to use the Measure tool, and select the Edge-Face-Vertex option.
Select both top and bottom edges or faces and the height will display. Measure gives you the distance between two points, edges, or faces.
