Cyan Lines on Projected Geometry on a Curved Surface
vishnumaiea
Message 1 of 11
vishnumaiea
So I was trying to project a feature to a curved surface that is not aligned to any axes. I created the feature by making a tangent plane (tangent to the target surface) and creating a sketch on it. I was able to project this feature onto the surface, but when finished, the sketch appears as cyan colored lines instead of a rectangular face that I could push-pull.
Projecting to surfaceProjecting to surface
Image 1 : Projecting feature to surface
Image 2 : No new face created on the projected surface.
If someone could shine some light on this, that would be appreciated.
Replies (10)
Message 2 of 11
JDMather
Split Face
or Patch and Thicken
Message 3 of 11
g-andresen
Instead of split face and press/pull you can use the extrusion tool.
1. Extrude from object
2. offset > Extrusion to object
depending on how the surface should look.
Message 4 of 11
vishnumaiea
Ah! That worked. Thanks. Still, do you know what the cyan lines mean?
Message 5 of 11
vishnumaiea
But here, the extrusion created doesn't follow the radial path of the curved surface.
Thanks for the reply anyway 🙂
Message 6 of 11
vishnumaiea
But by creating a patch and thickening it, we can.
Message 7 of 11
g-andresen
projected and linked to the profile > is updated when the profile changes
günther
Message 8 of 11
JDMather
I would be concerned about this.
Can you File>Export and then Attach your *.f3d file here for diagnosis?
Message 9 of 11
vishnumaiea
Yeah, that's an artefact created when I used the extrusion tool. Only noticed it now. It was due to a bad sketch profile. I corrected it in the timeline.
Unfortunately, I can't share the design file.
Message 10 of 11
g-andresen
It also works without plane and sketch.
try it this way:
günther
Message 11 of 11
vishnumaiea
Nice. Will keep in mind ✌️
