Cutting and Indenting a Curved Surface
ianhughes7UFVF
ianhughes7UFVF
Hi.
One thing that has always a problem, is when I want to cut a curved section and indent it slightly to create a detail on a surface.
In the pic you will see the V shaped area. I did a Split Face using a Projected sketch, but I actually want to cut that area and move it in a mm to make it a feature.
Is there a  correct way of doing this.
Kind Regards
Ian
jeff_strater
I would use an offset to do that.  Start Press/Pull, select your V-shaped face, make sure the type is set to New Offset, then type in -1mm as the offset.  If you can share your model here, I can show you on that model.
Jeff Strater
Engineering Director
ianhughes7UFVF
Hi
Thanks for the reply.
I haven't had the chance to try your suggestion, but here is the fusion file for you to look at.
Thanks for taking the time.
Kind Regards
Ian
ianhughes7UFVF
Hi
Your solve worked.
I have been adjusting the head really easily now.
Thank you so much.
Kind Regards
Ian
