Cutout in object
Cutout in object
Cutout in object
I'm a noob and I'm sure this is easy I'm trying to scallop out a portion of a design that I'm working on sketch photo included i can do a cutout that is x but is deeper on the tapered section and i want it the same depth.
I'm stuck and can't see how how to achieve it
Rob
daniel_lyall
You forgot to attach the pick.
Also can you attach your model.
Go to File -> Export and save as a .F3D Archive File and attach it to your next post
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Sorry my bad, in my haste I forgot the important bit Smiley Happy
I've attached model its probably more useful than pic
Rob
TheCADWhisperer
@Anonymous wrote:
... i can do a cutout that is x but is deeper on the tapered section and i want it the same depth....
You can Offset a surface and Extrude-Cut to the surface, but frankly, I would start over from scratch on this design.
You have a lot of symmetry in the design - I would place the center of Sketch1 at, well, the Origin Center Point.
You have several "sick" sketches (highlighted yellow).
In your second attempt if you get any sick sketches I would stop rather than continuing on and ask questions about how to fix the sketch.
By following this disciplined approach you will end up with a robust, rock solid model and develop good modeling techniques along the way.
Edit:  I went back and took a closer look at your Sketch1.  Since it isn't constrained to the Origin Center Point you should be able to drag it all over the screen without losing shape - but that isn't the case.  You are missing dimensions, geometry constraints and I recommend that you avoid Spline command for a while as a beginner.
The Equal (=) constraint (and Symmetric) should be your best friend.  They all should be your best friends.  You will have a lot of constraint friends by the time you get the hang of this.  Predictability will become your very best friend.
Excellent thanks for the helpful comments.
TheCADWhisperer
I was going to model this for you to demonstrate how I might do the design - but I ran out of time.
Be sure to post your next attempt and someone will recommend appropriate changes in technique if warranted.
