Cut Simple Sketch Curve
MaxHugen
MaxHugen
Must be the dumbest question I've ever asked, sorry, but how to you cut a simple spline curve into two?
Just draw any simple Fit Point Spline curve, then cut it in two, anywhere!
Dr Google is presenting me with all these much more complex examples of cutting - but not an absolutely basic method!
TheCADWhisperer
MaxHugen
Thanks.   However I wasn't expecting this to do a Delete as well.   I should have been more explicit - I actually need to cut a curve in two places, then delete the middle piece leaving the two outer pieces intact.
MaxHugen
All good, thanks. I should have been searching for "Break", not "cut" !
TheCADWhisperer
Uhmmm. That would be Trim.
MaxHugen
Yes, it worked OK with Break, but would have been simpler with Trim, now that I've read up on it. 🙂
22 days with F360, still a lot to learn!
