- Mute
- Permalink
- Report
Hi guys,
I created a mock of a part of my home / house.
I sweeped two circles along a path in the edges of the house as i want to place the Pipe - especially the bends - in the corner between walls and roof.
The long straits pieces will be aluminium pipes but the connectios need to be 3D printed.
The sweep is fine, now I want to isolate the BENDs.
When inspecting one of the attched pictures, one can see the transition of a "straight pipe surface" and a "bend pipe surface".
This is where I would love to cut / split them.
One can select the tiny "edge" between straight and bend, BUT i have no idea how to make use of the selected edge. !!!
If I could place a plane on the circle ( refer to Bend grey JPG ) - built by the edge - all would be fine, but no plane option ( to my mind ) does fit.
A simple delete of the selectable surface does destroy the rest of the pipe ==> no option.
Any good ideas?
pictures and stripped fusion files are attached here.
A good idea would be so much appreciated.
