Customize Marking Menu?
hitchcocksamuel
Message 1 of 8
hitchcocksamuel
I happen to never use the Press/Pull nor the Hole commands.  I would like to replace them in the marking menu with tools that would be more useful to me.  Currently I have changed the shortcut key for common commands as a workaround.  I'm looking for something similar to how CUI works in AutoCAD.  Thanks everyone
Replies (7)
Message 2 of 8
CGBenner
@hitchcocksamuel
Welcome to the Community. I've moved your post to this forum for better visibility. Good luck!
Chris Benner
Message 3 of 8
CGBenner
@hitchcocksamuel Hello, do you still need help with this question?
Chris Benner
Message 4 of 8
hitchcocksamuel
No. I gave up trying.  I'm spoiled by how customizable AutoCAD is and would like to make my workflow similarly fast in Fusion.  I'm not a ribbon clicker and was hoping the pie menu would solve this, but it's not possible any way that I can find.  Keyboard shortcuts can be one letter only, so there are only so many keyboard keys to remap.  Being able to tab through contextual boxes would be nice too, but that's another topic.
Message 5 of 8
adrian_aghai
Hit the letter "S" and type whatever you want and it'll pop up....It's much more straightforward than customizing pies.
I don't use pies, but it's also possible to customize the pie as well, type in "how to change pie shortcuts in fusion 360" into chat GPT and it'll give you an answer.
Message 6 of 8
laughingcreek
@adrian_aghai wrote:...but it's also possible to customize the pie as well, type in "how to change pie shortcuts in fusion 360" into chat GPT and it'll give you an answer.
This appears to be incorrect information.
Message 7 of 8
robotV52UH
There is a Marking Menu API Sample buried in the Fusion API docs here: https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-c90ce6a2-c282-11e6-a365-3417ebc87622
Been playing with this for about 10 minutes so far and I can confirm that this does indeed allow customizing the marking menu.
Message 8 of 8
m_tasWPLYT
Community Visitor
Community Visitor
Has there been a solution for 2026? Im not familiar with API integration. Can you give me a bit of starting help? Where do i start 😄
