Custom Thread XML File: Imperial STI Threads
AlanMueller
AlanMueller
Attached is an XML file with the thread definitions for creating internal STI (Helicoil) threads in models. There is no external thread support. This allows the creation of STI tapped holes, modeled and cosmetic, using the hole command, and creation of threads (modeled and cosmetic) on internal cylindrical surfaces. It includes thread data for coarse and fine STI threads from 0.073 (#1) to 1.5 (1 1/2) This was created and validated on Windows 10 and also tested on Windows 11 on the latest build of Fusion 360. However, not all thread sizes and drawing callouts were tested.
Traceability: All thread data was collected from a chart provided by Noble Aerospace Private Limited. You can find the link to the thread table here (http://www.noblefix.com/helicoil/HeliCoil-Tapping-Chart.html).
Methodology: Major diameters specified in the XML file are exactly as listed on the chart. Pitch diameters and minor diameters are averages of the minimum and maximum values for each thread specification listed. Tap drill size is the nearest drill in fractional inch size (1/64" minimum resolution) unless no fractional inch drill fell within tolerance. In that case, the drill diameter is to the nearest 0.1mm drill size.
Improvements: If any errors are noticed, please post a comment/reply on this forum thread. I want this file to be helpful to as many people as could use it. Thank you.
MRWakefield
Thanks for posting. I think it might be a good idea to have a thread (if you'll forgive the pun!) dedicated to custom thread files that people have made and would like to make available to others. I've got a bunch of thread files (including Wire Thread Inserts) I've created/curated  that I could post. I include some of them with my Fusion 360 Custom Thread app but I have others as well.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
