Custom Sheet Size
Custom Sheet Size
mrrichard
Custom Sheet Size
mrrichard
I am trying to change the size of a drawing. The most recent information I could find was from 2015. https://forums.autodesk.com/t5/fusion-360-design-validate/custom-size-sheet-drawing/m-p/5944272#M401... I'm wondering if anyone has any new information on this topic.
I am working on converting my high school CAD lab from Solidworks to the Autodesk family. I am currently working on some finger joint boxes. Students can use Fusion360 to build the model and prepare the parts for laser cutting. We then export a PDF and do the final document changes in Illustrator. I'm looking to remove a step and export directly to my laser cutter. Are there any changes to the drawing sheets so that I can create a custom sheet size?
Thanks for the help
Josh
High School CAD, Engineering, Robotics & Pre-Apprenticeship teacher
g-andresen
If it is to be edited, either use the tools in the Manufacture module or save sketches as DXF.
günther
mrrichard
Thanks!
I am new to Fusion360 and will explore the Manufacturing Module.
I'm currently putting induvial parts into a new file and nesting them before making a drawing with that file.
g-andresen
take a look at the arrange tool.
After arranging, you can project the entire arrangement into a sketch and save it as DXF.
günther
mrrichard
Thank you for all your help. I have a great launching point to learn more about the arranging tools!
