custom car dash
custom car dash
lucas.sealing
Message 1 of 10
custom car dash
lucas.sealing
hi all I'm kinda stuck on how how best to incorporate the dah cluster, air ride and boost controller into my dash can some one give me any help?
cheers
lucas
Replies (9)
Message 2 of 10
lucas.sealing
trying to add a 3mf file but getting errors sorry
Message 3 of 10
Warmingup1953
Open the model in Fusion, select the File menu and then the Export command and save to your hard drive. You then can attach it to a reply Forum post.
Message 4 of 10
lucas.sealing
Yup the forum won’t let me attach it
Message 5 of 10
Warmingup1953
What size is it? And can you confirm the file name and suffix?
Message 6 of 10
TrippyLighting
Zip the file before attaching it.
Message 7 of 10
laughingcreek
when you export it, it export as a .f3d file type. (or .f3z if .f3d isn't available)
Message 8 of 10
lucas.sealing
trying again but get this meeasge,
  • The attachment's cab scan v37.3mf content type (application/octet-stream) does not match its file extension and has been removed.
also f3z is to large
Message 9 of 10
TheCADWhisperer
@lucas.sealing wrote:
  • also f3z is to large
@lucas.sealing
From the image I don't see enough complex geometry such that the *.f3z file should be too large to attach here.
Can you save a copy as a different name and remove extraneous stuff that isn't needed to illustrate the issue and attach that file (preferably a *.f3d file with no external links).
Message 10 of 10
lucas.sealing
there's a hidden scan in there
