Hi
I created this Ribbed Cylinder in Fusion for a friend who is printing it in PLA and intends to use a heat gun to curve it perhaps 30 to 45 degrees:
It is 1mm thick so it should be workable.
What he really wanted was to have it already curved so it was printed in the shape required.
Unfortunately I couldn't work out how to create it other than manually drawing a curve between two lines and make up the compressed top and widened bottom effect. Creating a loft didn't seem to be suitable as I didn't think that would produced the compressed look.
Is there a way of taking this fusion model and creating a curve in it to achieve the desired effect, that of the ridges compressing at the top and widenening at the bottom.
Kind Regards
Ian
