Additional envoirnment updates
tarakant
Message 1 of 1
tarakant
After spending more time on model of some regenerative concept there is one irregular thing that seen is there is only 4 environment are available there only which is not sufficient for the model part. Apart of this every model which is being modelled in fusion 360. This is most important thing but as new update comes that then it doesn't update the environment.
So this is the new idea generation that in every update there would be one or two new environment provide so that it could be easy to perform render task. As after updating fusion every time there is a green line on the top of taskbar which shows that what is new in this update, hence like this there is there is link should be provided so that new environment can be downloaded.
Another way is to download the environment from various platform and some websites, as like this process I have downloaded about 27 additional environments, so new update must it and fulfil it.
Tara Kant
Replies (0)
