Curved bracket issues (probably a stupid question)
ryankheather
ryankheather
Im sure there must be a easy way to do this but I've been trying for a couple of hours now and cant figure it out. Pretty new to this, fusions my first attempt at any kind of 3D modelling, so I apologise if im doing some stupid stuff here!
Im trying to create a curved bracket with a extruded boss at the top for a cap head bolt to go through. To get this far I have sketched the profile curve and extruded it to a body, then extruded the profile of my bracket and intersected it with the curved body.  I have then used the thicken command to give the bracket a thickness of 6mm. To create the boss I have created a new extrusion from the sketch and then cut it using the sketched curve profile.
The problem I'm having is when I thicken the curved section of the bracket, it follows the angle of the bracket rather than the direction of the axis. This means I am left with some edges that don't meet up as you can see in the video.  What should I be doing here? is there another way I should be doing this?
Thanks in advance for any help !
TrippyLighting
You should:
1. Fix all the yellow and red icons before continuing, otherwise your design is simply going to break.
2. share the design some can possibly show a better way to do this.
davebYYPCU
Short answer is to use solids, to create the lower section of the bracket, the vertical section, as an extrude 6mm wide/deep.
Using the top face of that new plate, Sweep that profile along the top curve, using parallel in the type section of the Sweep command,
this will give the horizontal top edge of the curve plate I think you are asking for.
After cutting the side shape away, I would tie the circular boss to the resulting top edge
You should fix the errors,
For a new user you were not that far away from the desired outcome,
Of course there are other ways, as well.
Beyondforce
Hi @ryankheather,
I hope this will help:
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Owner, TESREG.com & Fusion 360 NewbiesPlus
TESREG - Fusion 360 Hardware Benchmark
Facebook | YouTube
ryankheather
Ok will do, thankyou for your help 🙂
ryankheather
 thankyou for your help! Should hopefully be back at the computer this evening, will give it a go! 🙂
ryankheather
Woah thankyou for the video!! Wasn't expecting that, people here are so helpful! I will give this way a try too when I'm back at the computer later and see how I get on, thankyou again! 🙂
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
