Curved Angled Cut
Curved Angled Cut
flotest
Message 1 of 10
Curved Angled Cut
flotest
I'm trying to remove the blue angled surface from my 3D model but can't figure out how to do it correctly. I've created a sketch on the surface but can't find the right tool to cut it out as shown in the attached images
Thanks in advance for any help
Accepted solutions (3)
Replies (9)
Message 2 of 10
g-andresen
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post.
günther
Message 3 of 10
flotest
Thanks for your fast reply.
File is attached.
VG
Flo
Message 4 of 10
jhackney1972
The attached video will explain the process you need.
If my post answered your question, please select the "Accept Solution" icon on my post.  If you have further questions please ask.
John Hackney, Retired
Message 5 of 10
g-andresen
delete double spline > create surface > split body
günther
Message 6 of 10
flotest
Thank you so much, I tried for 2 hours and couldn't find it and now it's so easy and done in a minute, thank you!
Message 7 of 10
johnsonshiue
Hi! Without seeing the model, I can only speculate. Another approach to create the desirable geometry is to use Draft command. The "cut" looks like the face being tapered to an angle.
Many thanks!
Software Test Engineer
Message 8 of 10
rqweb75
Question - You were adamant about using "remove" and not "delete" - can you explain to a newbie why the difference is so significant?  Thank you 🙂
Message 9 of 10
TheCADWhisperer
@rqweb75 wrote:
... can you explain to a newbie why
@rqweb75
I think it should be pointed out that everything done was done poorly.
Do you want to learn how to do this all correctly, or is "good enough" good enough for your needs?
Message 10 of 10
jhackney1972
If you use Delete, you will probably introduce a error into you model since you will be removing graphic information that the remaining model needs.  Remove, on the other hand, will retain all graphics information and preserve the integrity of your model.  Watch in the Animated GIF where I delete the Split Body and an error appears.  I will then UNDO the operation and use Remove and you will not see the error.  Even Fusion will try and warn me not to use Delete.
