Ctrl+B = Missing bodies and unable to see all bodies, components, canvases or
I was using the CTRL +V command when my %$#@!* finger slipped and I hit CTRL +B.
Every body, components, canvas and derive disappeared. I can't even create a new body.
For fun, in a new workspace I made a box and applied CTRL +B. To my astonishment, nothing happened.
I had a hundred active bodies being worked on. Are they just---gone? Closing and re-opening the file/program has not helped me to recover the bodies or components. Some have reappeared on the left under the list of bodies but they are not actionable. I can't edit them, move them or export to stl.
chrisplyler
The very first thing I would have tried, immediately after everything disappeared, is clicking the Undo button.
lichtzeichenanlage
Ctrl B calls Modify -> Compute All. This means, that all entries in your timeline will be recomputed. This can take some time.
Thank you to each of you for replying.
I did try the undo only it had no effect. I was able to find a keyboard overlay listing shortcut commands so I learned it was the "compute all" command but found scant little on what that entails. From the name I concluded it was as you stated but what I didn't understand was that this process runs while making it appear as if everything was deleted.
I probably lost everything as I closed Fusion360 when I incorrectly hoped a restart would provide a recovery file to open.
