Cross Section of Parts?
sneddonmark
sneddonmark
I have two parts  in my design a collar & shaft. I would like to have a cross section of just the collar. Showing the shaft without the cross section.
innovatenate
Autodesk Support
Autodesk Support
Currently the section analysis tool is a "global" analysis. It doesn't currently allow you to specify which bodies or components participate in the analysis.
You could manually work around this issue by using an extrude cut feature to emulate the section view.
You may consider requesting a feature on the Fusion 360 Ideastation to accomodate this workflow.
http://forums.autodesk.com/t5/ideastation-request-a-feature-or/idb-p/125
I hope this helps! Let me know if you have any questions.
Nathan Chandler
Principal Specialist
arwalker324
Is it still the case where one cannot select individual components/bodies to section?
(There are multiple requests for improvements to SA).
W.
g-andresen
YES!
günther
davebYYPCU
Well it only works on Visible bodies at my place.  (3 hidden)
Might help....
