Creating Vent on a Square
oystein.l.l
Message 1 of 20
oystein.l.l
how do i make this instead of cutting all the way through to cut at an angle making a vent? i hope im making sense..
Replies (19)
Message 2 of 20
hamid.sh.
Do you want to cut along an angled line? Then draw that line in a sketch and use Sweep to cut. Do you want to cut with a tapered angle? Then you have that option in the same Extrude dialogue.
Hamid
Message 3 of 20
oystein.l.l
i want a taper angle but from one side, extrude doesent do that, also sweep cut i have never used im pretty new to designing.. appreciate the help!
Message 4 of 20
aliobidi
see this
Message 5 of 20
oystein.l.l
howdy
Message 6 of 20
oystein.l.l
thats not exactly what im looking to do, im going to create a vent for the square hull body on the side profiles, i can show picture example
Message 7 of 20
oystein.l.l
i wanted to create scoops for the square hull body on all side faces, example here like the scoops vents for airplanes, basically vent scoop for the square body on all side faces1221-P-M-K(2493).png
Message 8 of 20
hamid.sh.
Still not sure about your requirement, but I am guessing it's one of these:
Hamid
Message 9 of 20
hamid.sh.
Then I think Sweep is the right tool. Check the one I attached in my previous post. You only need to make a path for the sweep. It can be sketch line, as I did in my file. But also you can do your normal extrude cut and later add a Draft on the faces (again like I did in my file, but only for one face).
Hamid
Message 10 of 20
oystein.l.l
no. i want a angle on bottom and a angle downwards from the top i can draw it 🙂
Message 11 of 20
oystein.l.l
Message 12 of 20
hamid.sh.
@oystein.l.l wrote:
Draw it on a sketch on the side plane and extrude cut it:
Or use Draft twice.
Hamid
Message 13 of 20
g-andresen
Targeted references require an insight into the current design.
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
Message 14 of 20
TheCADWhisperer
Is something like this what you are attempting to do (see Attached file)?
Message 15 of 20
oystein.l.l
Yes exactly just both should be symmetrical, looks good how did you do it?
Message 16 of 20
oystein.l.l
Also how do you get a view inside half the model? Always wondered that!
Message 17 of 20
TheCADWhisperer
Not sure what this means?
I just followed your hand sketch.
Can you create another hand sketch that more clearly shows your symmetry Design Intent?
Message 18 of 20
TheCADWhisperer
Inspection tab> Section Analysis...
Message 19 of 20
TheCADWhisperer
@oystein.l.l wrote:
... how did you do it?
Examine the Timeline.
The history of how I did it is recorded in the Timeline.
Message 20 of 20
oystein.l.l
Thank you so much for the help and time to explaining
