creating screws and holes
I have a part with a BUNCH of holes for a screw. I have one screw. Well that's rightly a component. I threw a joint origin on it to make this easier, BUT there's got to be a better way right?
Currently, The best way I can think of to do this is to create a joint at the first hole. Create a copy. Create a joint at hole2, ....oh wait. As I was doing that I crashed.
Well, you get the idea. I have to copy and create a joint for every hole.
That's not worth my time though. I think the engineer just had the screw hidden when he saved the assembly for me. So I'm just going to have him resave it.
Let me know if there is a good way to copy and place objects though. I did try one other thing, but it didn't work. I tried creating a sketch and creating a line snapping to the center of each hole. But you can't pattern along a line based on the line's parameterization. You can only do spacing between objects, and total number with even spacing. So I scrapped that.
What I'd really like, if it doesn't exist. Create joints as copies. After the first joint, any other joints you create would just create a duplicate component. Just keep clicking to create new joints of the same component. That would save SO much time.
