Creating multiple flat patterns from a single model file.
afrith
afrith
Can anyone tell me the correct workflow so that I can create multiple sheet metal flat patterns from a single Fusion file. I am trying to create a set of stairs bent from 1/4" steel plate but this has to be done in several parts so that they fit the sheet size. Fusion keeps telling me that I  have to create multiple components to do this but when I try that it says that function is not supported in Sheet metal. Any ideas?
Thank you
Alex
TheCADWhisperer
Did you create the parts as Components
or
did you try to Convert to Sheet Metal?
afrith
I started the first part as a component and then after that it will not let me create more . I have included the file if that helps. The different colored pieces reflect the separate parts.
jhackney1972
I have converted all of your sheet metal bodies into sheet metal components.  In the same assembly, each component can have its own flat pattern so you get what you wanted.  Since you quickly found out you cannot create a component from a sheet metal body, I outlined the process on one of your bodies to demonstrate the process I used.  Do not get yourself into this situation, create a new component, sketch, then create a sheet metal body, and the flat pattern.  Repeat this process over and over and you will not have any issues and a lot cleaner timeline.  What I did was a crude recovery of your model so do it correctly next time.  Model is attached.
John Hackney, Retired
afrith
Thank you for taking the time to solve this. I knew my workflow was incorrect and once i tried it your way it worked perfectly.
