Creating M19x2 custom threads on a nut
Message 1 of 16
I'm looking to create a nut with a custom thread M19x2 (metric m19 thread with a pitch of 2). I've looked on the thread list for metric and only see M18 and M20. I've also looked at the possibility of adding it manually via the xml file but it seems they all have custom values for each thread size. I don't have these values, what is the proper way to approach making custom threads?
Thank you for your help.
Replies (15)
Message 2 of 16
I'm currently trying this in %localappdata%\Autodesk\webdeploy\Production\<version ID>\Fusion\Server\Fusion\Configuration\ThreadData
Hopefully it works
    <Designation>
      <ThreadDesignation>M19x2</ThreadDesignation>
      <CTD>M19x2</CTD>
      <Pitch>2.0</Pitch>
      <Thread>
        <Gender>external</Gender>
        <Class>6g</Class>
        <MajorDia>18.822</MajorDia>
        <PitchDia>17.583</PitchDia>
        <MinorDia>16.5339</MinorDia>
      </Thread>
      <Thread>
        <Gender>internal</Gender>
        <Class>6H</Class>
        <MajorDia>19.2503</MajorDia>
        <PitchDia>17.807</PitchDia>
        <MinorDia>17.0224</MinorDia>
        <TapDrill>17.0</TapDrill>
      </Thread>
      <Thread>
        <Class>4g6g</Class>
        <PitchDia>17.6127</PitchDia>
        <MinorDia>16.5636</MinorDia>
      </Thread>
    </Designation>
Message 3 of 16
jonathanUGLA3
I'm not an expert on this, (I'm just now trying to create a custom thread using the XML file myself), but you may want to check out the wikipedia articles on thread standards. They have formulas for finding what the inner and out thread diameters should be based on the pitch etc.
Message 4 of 16
mjaddison
Observer
Observer
I know this is an old thread but thought other searchers may be looking for the same thing even now,
this site will calculate the values
https://www.amesweb.info/Screws/IsoMetricScrewThread.aspx
Message 5 of 16
marcorev
I am having to do the same thing. A M19x2 Internal thread for a Dremel adapter. Did your numbers work fine?
I am looking at the calculator website that someone posted https://www.amesweb.info/Screws/IsoMetricScrewThread.aspx
and your numbers for the external thread match with the average of the numbers  calculated there as average values.
For example: for Major Diameter you use 18.822 the website gives MaxMajor diameter 18.962  and Min Major diameter 18.682 the average is exactly 18.822.
This applies to all the numbers for the external thread.
However for the internal Thread (the one I need) I cannot get the numbers of the Major Diameter match with yours.
In your settings you use 19.2503. How did you calculate this number? the website doesn't provide a Max Major Diameter value but only the Minimum  that is 19.000
The remaining number (pitch and Min Diameter) are again the average of the number provided by the website.
Any help is appreciated.
Marco
Message 6 of 16
MRWakefield
I believe the thread on the nose of a Dremel tool is 3/4"-12 UN and is one that's included with Fusion.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Message 7 of 16
marcorev
comparing the dimensions between M19x2 and 3/4-12 UN they are pretty close.
Diameter 19 vs 19.05, Pitch 2 vs 2.117. Probably it is close enough for work given the low tolerance of the Dremel's nose
I will give it a try.
cheers
Marco
Message 8 of 16
gavin.landon
I've modified the xml, restarted, it still never shows up in the list.    Maybe something changed.   I only set M19x2.5.
<ThreadSize>
  <Size>19.0</Size>
  <Designation>
    <ThreadDesignation>M19x2.5</ThreadDesignation>
    <CTD>M19x2.5</CTD>
    <Pitch>2.5</Pitch>
    <Thread>
      <Class>6g</Class>
      <MajorDia>18.7905</MajorDia>
      <PitchDia>17.249</PitchDia>
      <MinorDia>16.938</MinorDia>
    </Thread>
    <Thread>
      <Class>6H</Class>
      <MajorDia>19.2925</MajorDia>
      <PitchDia>17.488</PitchDia>
      <MinorDia>16.519</MinorDia>
      <TapDrill>16.5</TapDrill>
    </Thread>
    <Thread>
      <Class>4g6g</Class>
      <PitchDia>17.281</PitchDia>
      <MinorDia>15.97</MinorDia>
    </Thread>
  </Designation>
</ThreadSize>
Message 9 of 16
gavin.landon
Nevermind, found my issue.   I was added to the existing..  Instead of creating a custom.  Looks like Fusion might have checks in place to ignore additions to existing files.
Message 10 of 16
Billyhall1
Community Visitor
Community Visitor
did this work in the end?
Message 11 of 16
elons1940
Observer
Observer
I have make work but you have to add the name at the top
<?xml version="1.0" encoding="UTF-8"?>
<ThreadType>
  <Name>Test_french</Name>
  <CustomName>Test_french</CustomName>
  <Unit>mm</Unit>
  <Angle>60</Angle>
  <SortOrder>3</SortOrder>
  <ThreadSize>
    <Name>CustomACME</Name>
    <Size>19.0</Size>
    <Designation>
      <CTD>M19x2.5</CTD>
      <Pitch>2.5</Pitch>
      <Thread>
        <Class>6g</Class>
      </Thread>
      <Thread>
        <Class>6H</Class>
      </Thread>
      <Thread>
        <Class>4g6g</Class>
      </Thread>
    </Designation>
  </ThreadSize>
</ThreadType>
I hope it will help somebody 😊
Message 12 of 16
Drewpan
Just wondering why you need custom threads? Is it a design exercise or some other reason?
Only asking because Standards are there for a reason. If you design a custom thread then you have to
actually hand make the fasteners, or specially machine as the case may be.
I get that there is nothing actually wrong with custom threads and that some manufacturers deliberately
use them for proprietary purposes. I am learning to be a design engineer so off the shelf is much cheaper than
custom designed parts. I would only use a custom fastener if I really had to and couldn't either redesign
my part to use the larger standard part or the smaller one did not have the required safety factor.
As Andrew S. Tanenbaum says - "when it comes to Standards, there are plenty to choose from", so why create
even more.
Cheers
Andrew
Message 13 of 16
marcorev
It was for a nut to fit a dremel. So you should ask Dremel why they didn’t use off the shelf standard 😀
eventually I used a 3/4-12 UN  as it is pretty close and with plastic 3d printing is good enough.
cheers
Marco
Message 14 of 16
Drewpan
Ok,
So Dremel using them for proprietary reasons. 🙂
Cheers
Message 15 of 16
riegler268
Community Visitor
Community Visitor
Hallo,
Unter: "C:\Users\"DeinName"\AppData\Local\Autodesk\webdeploy\production\xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\Fusion\Server\Fusion\Configuration\ThreadData" findest du einen Ordner mit der Datei "ISOMetricprofile.xml" diese kannst du mit Editor einfach bearbeiten füge dafür den Codeabschnitt mit M19.2 hinzu nach dem neu Laden bekommst du das neue Profil.
Code:
<Designation>
<CTD>M19x2</CTD>
<Pitch>2</Pitch>
<Thread>
<Class>6g</Class>
<MajorDia>18.917</MajorDia>
<PitchDia>17.917</PitchDia>
<MinorDia>16.835</MinorDia>
</Thread>
<Thread>
<Class>6H</Class>
<MajorDia>19.000</MajorDia>
<PitchDia>18.083</PitchDia>
<MinorDia>17.376</MinorDia>
<TapDrill>17.4</TapDrill>
</Thread>
<Thread>
<Class>4g6g</Class>
<PitchDia>17.937</PitchDia>
<MinorDia>16.855</MinorDia>
</Thread>
</Designation>
Viel Spass
Message 16 of 16
MRWakefield
Apologies — I don’t speak German, so I’ve used a translator. I hope I’m understanding you correctly.
It seems you’re suggesting editing the "ISOMetricprofile.xml" file to add the M19x2 thread. I wouldn’t recommend this approach, as any changes to this file will be lost the next time Fusion is updated — the installer will overwrite it. That’s why it’s best to create separate custom thread files, which aren’t replaced during updates.
However, there’s one more thing to be aware of: when Fusion updates, it often changes the storage location for thread files and won’t automatically copy your custom ones to the new folder. To avoid losing them, I recommend using the ThreadKeeper add-in, which automatically copies your custom thread files to the correct location after each update.
Hope this helps.
Marcus Wakefield
