Creating joint gives an error - This joint would form a conflict. But I don't know what's the conflict.
vsagar1
vsagar1
Modifying this model of a box and created all the rotational joints for all the hinges. The joints highlighted in black throw me the error, but it doesn't show me or tell me what the conflict would be.
https://a360.co/3AEcIQk
^ here's the link to my project.
akash.nawghare
The Hinge & Top lid is not aligned so when you are trying the create a joint it is getting misplaced & creating a conflict joint. Try to align the Lid & then create a joint will get fixed.
"If you find my answer solved your question, please select the Accept Solution icon"
g-andresen
If you correct the position of the lid, it should work.
günther
g-andresen
1. in the screencast, I show how to position joints precisely by centering them with the “between surfaces” option.
2. using the “Duplicate with joints” tool, I create a second joint.
3. The mesh elements in this design make it difficult to position joints as they do not allow access to an axis of rotation.
These parts should be replaced in advance with “clean” solids.
günther
