Creating internal tapered tube (f3d attached)
877cms
877cms
Good afternoon,
Could anyone advise if there is a way to create this internal taper, so that the bottom part is at the inner circle of sketch2 (indicated by red arrow). Currently I can do it by trial and error, adjusting the draft angle to -1.5 degrees, but I think there may be a better way.
jeff_strater
here is one way, using Loft:
Jeff Strater
Engineering Director
g-andresen
Hi ,
try this
Screencast
günther
jeff_strater
here is another way, using Revolve:
Jeff Strater
877cms
Seems @jeff_strater and @g-andresen had the same idea, thank you both. I tried that myself and it works and is easy to remember 🙂
I'll look at the revolve method, but honestly I'm best not confusing myself!
