Creating icosahedron error
fokuspace
fokuspace
Hello. I'm stuck at creating icosahedron. The angle between faces is 138.2 degrees (acos(-sqrt(5)/3)). Components are connected by joints. As you can see, last 2 of 5 faces did not fit, something is wrong. Please, send help!
Stuck at creating icosahedron in Fusion 360 errorStuck at creating icosahedron in Fusion 360 error
TrippyLighting
Try this:
fokuspace
Thank you very much for quick solution. Great tutorial.
PS. For icosahedron rotate components for 72 degrees on golden ratio planes axes.
