Creating groove on an angle
Fueler
Fueler
While I am terrified of cutting wood on my mill I have a Christmas present to make.
It is a breadboard with a juice groove.
I am stumped on how to get the drain groove (red arrow) to angle down and meet the perimeter groove which is deeper.
Failed at everything I tried so far.
Anyone with tips and hints?
davebYYPCU
Just need a Sweep,
the bottom of the proposed groove, is the path, and a simulated milling cutter profile is the profile.
Trick is to look at it from the side as per pic.
File attached, used your setting out to make a Sweep cut, read the time line back, with Edit feature to see my settings
You could also save a lot of work with the main groove by making a simulated router bit and a centreline track, for an all in one sweep for the main groove.
Many ways to get things done, just one way.....
Fueler
I seem to have it figured out now based on your info.
However I am failing in finding a way to CAM that slanted pocket with a 1/2" ball end mill.
Am I missing something obvious?
What selection and operation would you choose to machine it/
etfrench
You have two choices:
  1. Make the radius of the slots slightly larger.
  2. Lie about the size of the endmill and make it slightly smaller.
You can't mill a slot with the exact size end mill.
ETFrench
Fueler
Aware of the size issue. Tried that.
My biggest issue here is choosing a proper tool path and the proper 2d or 3d operation to pull it off. Nothing normal seems to work
I'm overlooking something.
davebYYPCU
Sorry, I can't advise on CAM stuff.
I would take the question to their forum, there are guys there that don't come into this one, so much.
Fueler
Will do. Thanks again
