Creating Drawing from Design with PCBA, Silkscreen Issues
connor_d_brown3
connor_d_brown3
Hi, I am creating a new drawing from a design that includes a PCBA. I have lined everything up in the design and when I create the drawing, the Silkscreen for the top Layer of the PCBA Model component is being associated with other components. I have hidden the PCBA model component in its entirety and this is what I am still left with:
Warmingup1953
PCBA stands for Printed Circuit Board Assembly
connor_d_brown3
Yes, my apologies, I should have been more specific.
liang_chen
I am not quite sure if I understand the issue correctly. If you are talking about the fastener left in your snapshot, will it be in the folder of fastener? It need to be hidden separatedly.
Please share the details and dataset if there are other issues. Thanks
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
connor_d_brown3
No, the issue is that the other models are all visible, while the PCBA (board) model is hidden. The Silkscreen is still visible from the PCBA Model even though it is hidden, and bleeds through other components in the model as well:
When I turn the Reference Designators off, the issue goes away:
Could this just be a bug in how the model gets exported to a drawing?
liang_chen
Thanks for sharing the snapshots, while we need the dataset to reproduce and investigate the issue. Do you mind to share the dataset?
Fred Chen
SQA Engineer
Autodesk, Inc.
