creating a volute
creating a volute
creating a volute
I want to create a volute as decorative part of a clock case. I have already build a kind of staircase model and now I want to make the curved surface smooth but I don't know how. I tried to use a spline as a sweeping path but I can not use the corners of my staircase model when I draw the spline. Can someone help?
Best regards
Joerg
TrippyLighting
I've attached what I think you are looking for.
In the end of the screencast I am trying to edit the inside diameter but it does not have an effect because I only change the diameter of the small inside coil.
You'd also need to carefully edit the angle on the first larger coil, at least the way it's designed in this file.
Thank you for your reply,
I will try it, but the main problem is that the volute I want to create is quite more complex because it has a lot of features like oval shape, and a somehow tilted surface. It should be exactly according to the dimensions I have measured from a photo. I fear with your solution it is not possible. Attached are two pics of my basic sketch and the photo analysis I have done.
Best regards
Jörg
TrippyLighting
That can be done as well but it will be a good bit more involved.
The technique is the same, but creating the splits for the sweep will be more complicated,
dyefroy1
Community Visitor
Community Visitor
I am trying to
make a simple volute and just saw your tutorial. It is a very smart approach but for some reason my sweep is not forming, even though I used the same values as you have. It is just giving an error.
Would you have any suggestions?
@TrippyLighting
TheCADWhisperer
@dyefroy1
