Creating A Tapered Hole
ewandivitt
ewandivitt
I need to create a tapered hole in a rod, and I can't seem to figure out how to do it.
I tried to sketch the profile of the taper, and then revolve it, and then draw the rod around it and use the extrude function to remove the tapered object. That doesn't seem to be the correct way.
Any help is greatly appreciated,
Ewan
innovatenate
Autodesk Support
Autodesk Support
Here's a couple screencast showing how you might accomplish this.
http://autode.sk/1Ki1gbY
http://autode.sk/1WTSUsX
Hope that helps!
Nathan Chandler
Principal Specialist
ewandivitt
Thank you very much.
I was unaware of the first method, but the second method is very logical now that I see it being performed.
Screen casts are such an amazing feature.
jeff_strater
There are a couple of ways to do this, assuming I am interpreting your requirements correctly.
You can use Extrude of a circle with a taper angle or Revolve.
Here is a screencast showing both methods:
Hope one of these works for you.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
robert_stevenson9XZZV
Observer
Observer
Beautifully presented - thank you. (So jealous of your skills 🙂
ka1ycj77
Community Visitor
Community Visitor
This is Awesome Info!!! I like the second option because you can make any contour you want.
