creating a ruled surface
I apologize for how messy this is. I am switching from mastercam and trying to figure out how to take these guide sketches and create a surface with them. In mastercam I use ruled lofted surface. I am including the file I am working on. Interested in how this is done in fusion, dont need somebody to do it for me as I will need to do this alot in the future. Thanks!
TrippyLighting
My recommendation would be to re-design this completely from scratch in Fusions 360.
The imported geometry is pretty broken.
jhackney1972
There are sketch segments mixed up in different sketches.  What you have to do is project the sketch segments you desire onto a new sketch making sure you have a closed profile.  Then you can use the Surface "Patch" tool to create a surface in your new sketch.  Take a look at the screencast.  If I missed the boat and I am not doing what you desire, please post an updated description of what you want as a resulting surface.  What are you going to use the surface for?
John Hackney, Retired
Hey there!
Missed the boat a bit but I really appreciate it! I was unclear with what I am looking for. I am aware things are on different sketches as this was exported from mastercam, I didnt design it that way. New file attached. Example file for reference
Please see the new file and example. I am looking for a very specific complex surface that would be very hard to simply re design. Can you provide some examples of technique?
jhackney1972
It looks to me you have already made your surface in the example file so I cannot add anything.  If you want to make it a solid, just use the "Thicken" command, or close it in on the other side with surfaces and it will become a solid automatically.  If you have multiple surfaces and wish to joint them together use the "Stitch" command under the Surface commands.
The example file is a different surface. I need to do what I did to the example in mastercam with the new file in fusion 360.
