Creating a Relief Patterned Sphere
I was just curious if anyone knew of an efficient way to project a pattern onto the surface of a sphere in such a way that it retained equal proportioning across the surface- such as the superposition of torus indent or projections in the hex shaped coordinate system generated by triangular vertices used to approximate a sphere.
Here's an image for reference!
https://goo.gl/images/KrKpjT
Short form is looking for a way project patterns which retain proportionality across a spherical (or curved) surface rather than being distorted by a quadrant based, orthographic mesh (perspective!) S'rry if I'm being ignorant! Very new at this and wanted to know the best route!
TrippyLighting
That spent in you animated gif was created in Blender and that is exactly where I would model it.
If you absolutely need a solid model, then import the undivided sun-D mesh from Blender as a .obj file and convert it into a BRep. That way it'll maintain its polygonal character.
