Creating a Jpeg file from a Wire Frame
I would like to export a jpeg file from a wireframe produced in Fusion 360.  I am using the Capture Image function under File.  It is producing a very patchy wireframe with lots of dots. It is almost like it is having resolution issues.  I have changed the resolution with no improvement.  Is there a way to get a good jpeg out of Fusion 360?  I am creating my image from thin extrusions and turning the sketches off so construction points are not the issue.
filipmatyja
Hello steina81,
You can try open your project as drawing and extract is as PDF. Then you can do whatever you want with it, as it's saved as vector graphic without loss on the drawing quality. The other very handy thing is that you will be able to zoom as much as you want without pixelation of the drawing.
Please find difference between screen capture and print screen from PDF I've just made.
Hope this will help you out,
Filip
