- Mute
- Permalink
- Report
Greetings,
I'm not sure if I have the concept of joints and their functionality confused, but here we go:
I have a cable carrier I've designed. Component 1 = Female link (Right), and component 2 = Male link (left). The Male and Female links have four sub-components = 4 parts.
None of the parts in either the Female or Male components have been joined using rigid joints. What do I do in order to join both of these links without having this happen below:
Originally, I went step by step, grounding 1 sub-component, then added a joint step-by-step, over and over, 1 part at a time. Is it possible to have the joints already defined per "link" (female to Male to female... etc) without having the above happen? I tried using rigid groups and that doesn't seem to help me do this.
Is it possible to treat each component that has sub-components as just 1 component when adding a joint between the two components (with sub-components).
I'm wondering if I'm approaching the concept of "joints" correctly. The only way I can think of each component doing what I want is if each of the sub-components were actually bodies within the Female and Male links instead of being separate components. Is that the only way it would work?
I hope this makes sense.
Thanks!
