creating a dxf from a sketch does not copy text to dxf
chrisYBGLU
chrisYBGLU
creating a dxf from a sketch does not copy text to dxf!
James.Youmatz
Autodesk Support
Autodesk Support
Hi @chrisYBGLU,
I don't believe that text is supported in DXF files, but I will dig deeper into that. In the meantime, if you need the text to be exported into a DXF file, all you need to do is highlight the text, and then right-click it and select Explode. Once exploded, you can save the DXF and the text profile will be saved in there.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
