I'm trying to create a curved sheet metal part. I will be rolled manually, but I need to know the unfolded shape to have it cut.
I'm starting with the sketches, one above the other. Each sketch has a line in U shape that is NOT aligned to the other one. I then used a surface loft tool to create the surface between both sketches, then I created a sheet metal part. When I try to flatten it, I get this error:
Can't complete sheet metal operation due to model compute error.
Any help will be appreciated!
