Creating a curved sheet metal part
odm357
odm357
I'm trying to create a curved sheet metal part. I will be rolled manually, but I need to know the unfolded shape to have it cut.
I'm starting with the sketches, one above the other. Each sketch has a line in U shape that is NOT aligned to the other one. I then used a surface loft tool to create the surface between both sketches, then I created a sheet metal part. When I try to flatten it, I get this error:
Can't complete sheet metal operation due to model compute error.
Any help will be appreciated!
m.sachin.krishna
Autodesk Support
Autodesk Support
I have attached a reference file with the outcome you need. Let me know if it helps in any way. You can go through the timeline and see what I have done.
I created a sheet metal component from the Sheet metal tab first and used the flange command to extrude up to a certain distance and I offset a plane. Used this plane to split the body to get what you need. Now the sheet metal component can be made as a flat pattern. You can change the thickness in the sheet metal rules.
Thanks.
Sachin Krishna
Fusion 360 Product Support
odm357
thanks a lot @m.schin.krishna.
It's very close, but it is not touching the second sketch at the top.
I think that is what makes it difficult.
jhackney1972
I think this is what you want.  Model is attached.
John Hackney, Retired
jhackney1972
Did my post solve your issue?  If so not forget to mark the Forum post, that solved your question, by selecting the "Accept Solution" icon. This closes the question, makes the solution available to others with similar questions and acknowledges the solution as helpful. If it did not answer your question please post any further questions you have.
vanessadebono95
Community Visitor
Community Visitor
this help so much, thank you!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
