Create triangular geometry without singularity
Message 1 of 10
I am trying to create a boat hull geometry. At the end of the geometry it will end up in a triangular geometry. What would be the best way to create geometry like this in Fusion 360?
I can do it in Autodesk Alias
I have attatch links with videos of the approach in Alias and Fusion 360
Hobe someone have an idea.
http://autode.sk/2aiJmIp
http://autode.sk/2aiKI5U
http://autode.sk/2aOBRaB
Replies (9)
Message 2 of 10
PhilProcarioJr
@Anonymous
Can you save out your curves in a .f3d file and post them so we can take a look at it?
Also is there a reason your using T-Splines, not that you can't or that its wrong just wondering why you picked them for this.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 3 of 10
Hi Phil,
here are the files you aked for. The Alias Wire file are the original.
Kind regards
Renè
Message 4 of 10
PhilProcarioJr
@Anonymous
Actually if you want this a T-Spline switch over to your sculpt environment and select both surfaces. Then Tools -> Convert...here is a video Let me know if this is what you wanted to do.
Phil Procario Jr.
Message 5 of 10
Hi Phil,
i know that option. But what if i whant to start from scratch?
Message 6 of 10
PhilProcarioJr
@Anonymous
To be honest T-Splines are finicky with what your doing here. I made another video showing how from scratch but you will see that you need more guide rails to make this from scratch.
As soon as the video uploads I will post it.
Phil Procario Jr.
Message 7 of 10
PhilProcarioJr
@Anonymous
As you will see you can create them manually but you will need more curves to make the shape accurate between the edges. The only other option I know is to tweak the vertices manually in between curves. The side of the boat could be done the same way using the top curve and bottom as a guide but the front can not.
Phil Procario Jr.
Message 8 of 10
PhilProcarioJr
@Anonymous
Actually I have a better way give me 5 min to post it.
Phil Procario Jr.
Message 9 of 10
PhilProcarioJr
@Anonymous
Is that what your looking for?
Phil Procario Jr.
Message 10 of 10
it was exactly what I wanted. Becoming more and more impressed by t Spline technology in Fusion. Everything about Fusion and the user community is absolutely fantastic.
Thank you for your feedback
Spoiler
Spoiler
Spoiler
