Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Create the silhouette of an object
2 REPLIES 2
karthur1
2691 Views, 2 Replies
karthur1
How can I go about creating a silhouette of an object in Fusion360?  Like the shadow that is cast on the ground plane in the image.... is there a way to get an actual silhouette of the part without a bunch of complex geometry?
2 REPLIES 2
deyop
in reply to: karthur1
deyop
A new command added in the last release may be able to split the model, from which you could project the edges to a sketch plane.  The Parting Line Split command will take solid body input and a direction to split the body at a line which could be defined as the "silhouette".   Try this out and let us know how it worked.  I have had some difficulty consistently getting results so we would like to know if you had any problems.
karthur1
in reply to: deyop
karthur1
Paul,
I tried the "Parting Line Split" command. I first had to shell the body. Then when I tried the command, it pretty much previewed what I wanted.  When I accecpted the preview, it failed.
Kirk
Paul,
Kirk
