Create sketch on cylinder in sculpt
What is the best way create a skecth on surface? I'm trying to make a design on the surface of cylinder.
Accepted solutions (3)
James.Youmatz
Autodesk Support
Autodesk Support
Do you think you could clarify a little more for me? Are you trying to sketch on the circular faces of the cylinder (the flat face) or are you trying to sketch on the rounded part of the cylinder? My guess is you are having trouble with the rounded part, right?
James
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Thank you for the quick response. Yes, I'm trying to make holes and add
some more design on the rounded part of the cylinder. Do you think sculpted
environment is suitable to my design?
Thank you
Baigalmaa Batmunkh
Graduate Student
Department of Industrial and Enterprise Systems Engineering
University of Illinois at Urbana-Champaign
batmunk2@illinois.edu
James.Youmatz
Autodesk Support
Autodesk Support
Not a problem! I've made a screencast below that shows how to project your sketch to a surface, in your case the cylinder face. This is a pretty handy tool that I think works really well.
http://autode.sk/1UlQQJf
In your case though, there may be an easier option to create holes in your cylinder body. In my screencast you'll notice that I created an offset construction plane. What you might wanna do is create the circle in that sketch and then extrude it through the cylinder using the "Cut" option in the "Extrude" command. Attached is a screenshot showing what I mean.
Hopefully this clears up some confusion! Let me know if you have any more questions.
James
James Youmatz
Hi there!  Besides the great advice James gave, here are some previous related threads with suggestions that may be helpful:
http://forums.autodesk.com/t5/design-and-documentation/joining-two-components-together/m-p/5688033/h...
http://forums.autodesk.com/t5/design-and-documentation/hole-starting-on-rounded-surface/m-p/5706417/...
Hope you get it figured out.
Jesse
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Just wanted to check in with you and see if the methods that @Anonymous and I posted worked for you? If so feel free to accept those answers as solutions so other Fusion 360 users experiencing similar issues can benefit from this thread!
Cheers,
James Youmatz
Hi James,
Thank you for checking with me. Yes, the tutorial that Jesse provided with me as well as the additional sources you sent me was very explicit and helpful. I appreciate it a lot.
Best,
