Create parametric object from mesh surface (3D scan)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all, I'm trying to create a duct for a bumper (350Z) and I figured the best way to replicate the surface would be to 3D scan it and build a model from there.
I'd consider myself a novice in Fusion, having designed a printed several components already, but working with scanning and meshes is very new to me.
Excuse the ordinary mesh in the example below. It was my first attempt with Polycam (on a Pixel 7 Pro) and I intend to go back and play around with lighting, surface prep etc.. to see if I can get a better result. The subsequent workflows are more important.
I read a few posts and watched a few videos and got as far as attempting to use 'create mesh section sketch' which has done a good job at outlining the section I want to replicate, but I thought I'd stop there and ask the pros. Ideally I want to create a parametric surface that mimics the mesh area and from there I can build the model no problems.
Thanks ahead 🙂
