Create New Simulation Bug
neljoshua
Advisor Advisor
neljoshua
I created an assembly and then performed a static simulation on one of the components.  I was going to try using the shape optimization features in Fusion.  When the New Simulation window appears, however, I get some interesting results.  It is not clear what is selected, nor are all of the options visible.
I am restarting to see if that helps, but I wanted to capture the Screencast first.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
neljoshua
Re-starting Fusion does not change this behavior.
Note: this only happened after I already had created and completed one simulation.
__
AndrewSears
@neljoshua, we are aware of this issue with MAC's and are working on a New Study dialog that will remove this problem.  We do not have a set release date for this yet.
The workaround for now is to create any study and change it in Manage/Settings.
Andy
neljoshua
@AndrewSears,
Thanks for the update.
__
shigeaki.k
Hello @neljoshua,
could we check what OS version and Fusion 360 version you are using? On Fusion 360 v 2.0.2727 and with MacOS 10.12.3, the issue seems to have been resolved.
Shigeaki K.
Shigeaki K.
Technical Support Specialist
サポートとラーニング | Support & Learning
neljoshua
@shigeaki.k
I am using OSX 10.12.3.
Fusion is version 2.0.2727.
__
shigeaki.k
@neljoshua,
Interesting. We have a similarly setup MacBook Pro, except it has dual graphic systems.
Shigeaki K.
Shigeaki K.
