Create multiple bodies at different points
c.m.ivanyi
c.m.ivanyi
Community Visitor
Community Visitor
I want to create a 3d pattern of 1000 spheres.
I created a .csv file with the x, y, z coordinates. If I import this file I get a 3d spline with 1000 points on it. The pattern is a spherical Fibonacci spiral, so the pattern tool in Fusion does not work for my design.
Is there a way to create the sphere in one step at all of the coordinates?
Thanks a lot!
Charlotte
(The image with the golden spheres is what I want to achieve, the screenshot from Fusion is what I have so far and where I am stuck. The only solution I can think of is to copy paste a sphere to every single point... If there is another way to create a Fibonacci sphere that would also be really helpful!)
TrippyLighting
There is no tool accessible through the usual menus that can do this.
However, Fusion 360 does have a Python API!
My guess is that the CSV import was done with an addon using that exact API. Creating a sphere on one of these imported points editing that Python addon might be a relatively easy task. It is much more memory efficient to create a sphere body inside a component and then instance that component 999 times rather than  creating 1000 separate bodies.
rushabhthakkar_910
@c.m.ivanyi, This could give you an idea..!!
(https://youtu.be/hkMfm5SXSNE)
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
g-andresen
Maybe it can be done with this tool
günther
