Create miter cuts
Create miter cuts
sfisk
Create miter cuts
sfisk
I have a design with 4 components (2 x 2 angle). I want to trim the components to make mitered corners. How can this be done?base 1 v2.png
etfrench
  1. Watch the learning videos: http://help.autodesk.com/view/fusion360/ENU/
  2. Create a sketch.
  3. Project the outlines
  4. Draw lines at the miters' positions
  5. Close the geometry by drawing rectangles (if necessary)
  6. Extrude the geometry using the Cut option to remove unwanted portions of each side
ETFrench
g-andresen
here is a solution if the finished profiles are really to be cut.
günther
g-andresen
here is a solution that was also called by etfrench and a variant of it.
http://autode.sk/2strbbZ
http://autode.sk/2tw6afp
günther
