Create manual exploded view using sub-assemblies
clm_dasher
Message 1 of 1
clm_dasher
Hi Folks,
This question has been asked in a way a couple of times before on the forums but I've not been able to find a good answer.  The Animation workspace of Fusion allows me to create sub-assembly views.  It gives the option of an auto-exploded view with either 1 level down or all levels.  Or I can manually explode.  I am trying to make an exploded view of the top level sub-assemblies.  The issue is that the auto exploded creates a view that explodes sub-assemblies in the wrong directions.  And (AFAIK) the manual view does not allow you to explode sub-assemblies, only components.  My current work around is to make views by translating sub-assemblies but this excludes features like extension lines.
Does anyone have experience of creating sub-assembly exploded views / a better workaround / a solution?
Cheers,
Carl.
Replies (0)
