Create lip groove
Create lip groove
Create lip groove
I want to create an enclosure with two parts coming together as smooth as possible. I want to acheive this by creating a lip groove so the two parts interface together. Something similar to this tutorial in Solidworkds: https://www.youtube.com/watch?v=kq1jNkvByyo
How would I do this in Fusion 360?
LMD001
Hello Andrew,
Besides writing a script, there is no Lip/Groove command, but you already knew that.
Take a look at the file.
Mind you, this is by no means the only way to create this, but I found this a rather quick way.
Hope this helps.
Best regards,
Ludo
jeff_strater
Yes, there is no high-level lip/groove feature in Fusion as in that video.
However, you can get a pretty good lip just using Sweep:
starting point:
start by putting a Workplane on Path around the split edge:
Create a sketch on this plane, then add some geometry that defines your lip:
Then, use Sweep to remove material from one side:
Then, using the same sketch, add material to the other side:
then, you have a nice lip that fits together (I've moved the top up to show the geometry):
Hope that helps you
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
