If there a way, either in Fusion, Mesh Mixer or Cura, to define some minimum width between touching bodies or to shrink a body (so that there is a gap between them) so that one will fit inside the other?
I know I can use push/pull on faces, or scale a whole body. Is this the correct way to do this?
Solved by davebYYPCU. Go to Solution.
Solved by etfrench. Go to Solution.
A joint would be the proper way to do this, although you'll need to test how Cura will interpret the different origins for the parts.
Measure, then Scale
Designing in place would be another option.
ETFrench
There is, Cura is probably the same as my slicer,
load both, change one to provide the gap, by scaling in X Y but not Z, by say 2%
Therefore the owl would be 98%. Size is by testing for most printers.
Might help....
When I have to build two pieces of a housing that must be joined together with an overlapping edge (one recessed, one extended), I first draw a splitting line on the Sketch where I want to modify the feature. Then I split the body with that line as the splitting tool. Next, I use Offset Face to adjust the feature on the split body section that I want to change. Finally, I use Combine to execute Join, Cut, or Intersect of the fixed body and the modified split body, depending upon which Boolean operation you desire.
Here is another solution - it is analogous to using two cookie cutters on your body
For example if you wanted to create a
