Create 'flowing' body between faces / lines
Ferry0
Observer Observer
Ferry0
Observer
Observer
Hi all, I'm relatively new to Fusion and am having trouble finding out how to resolve this
I have two surfaces of a body and would like an 'organic' fillet between them while preserving the edges (selected in blue in snapshot below). I would like to create a sort of 'saddle' shape between the faces, if that clarifies anything. A regular fillet would not work here since the left and right edges would then be modified. What tool in Fusion could I use for this?
Should I use some form of the fillet tool or create a 'form' in the form tool?
jeff_strater
I don't know about others, but I am having trouble visualizing what this result would look like.  Here is a variable radius fillet with a few points, and zero radius on the ends.
Jeff Strater
Engineering Director
Ferry0
Observer
Observer
Thank  you Jeff! This is indeed what I am looking for. I was very close to this solution already, but for some reason I wasn't able to add radius points by clicking '+' on the menu. I had to click on the edge to add lines, which works as well. I will play around with this and get the shape I want.
Have a great day!
