Create bars from lines
10:24 AM
I made a sketch with a lot of triangles and squares drawed as lines. Now i want to make square bars out of these lines.
First i was thinking about using the pipe command, but i guess because they are triangles and squares that are close that this command doesn't work.
I'm also uploading a screenshot of what I'm working on.
So this lines i drew in sketch environment would need to be converted into square bars.
When i go into create environment, i can use the pipe command but then i get the pipes but the are rotating pipes and i get strange 3D things. Looks like they are welded together.
So what i need it to give the lines an easy with of 2 mm or so (2D or 3D, 2D is also great cause i can just extrude).
Any help or tip is welcome 🙂
